HeightField Noise artifacts in viewport
1444 7 1- g0rka
- 16 posts
Hi Friends!
Perhaps some of you have already encountered a similar problem.
When working with the HeightField Noise, strange artifacts appear in the viewport (see screenshots). These artifacts appear when you look at the plane (the surface of the earth) from the side, and in the top view they disappear. With what it can be connected? Software glitches? or an incorrect combination of viewport and node parameters?
Thanks in advance!
Thanks in advance!
Edited by g0rka - Jan. 5, 2023 02:24:01
- Enivob
- 2539 posts
- Siavash Tehrani
- 710 posts
- g0rka
- 16 posts
Enivob
Can you post your HIP file? Everything looks fine on my Windows 10 system running H19.5.435.
Post your hardware and software versions.
Upgrade to the latest...?
Please check attached file
H19.0.589
macOS Ventura 13.0.1
2,3 GHz quad-core Intel Core i5
Intel Iris Plus Graphics 655 1536 Mb
8Gb 2133 MHz LPDDR3
- g0rka
- 16 posts
- Siavash Tehrani
- 710 posts
- g0rka
- 16 posts
- yolomag
- 8 posts
g0rkaSiavash TehraniThank you, Siavash! Now the reason is clear.
I opened your file and the heightfield looks normal on my end. Your Intel graphics card doesn't meet the minimum system requirements, it may be related to that.
Hi g0rka, I have the same Mac system and graphics card, so I've been having visual issues as well. Just wondering, have you found a way to make this work?
