Any documentation about pdgattribvals function?
890 2 2- happybabywzy
- 86 posts
- Robbert
- 53 posts
The documentation is here; https://www.sidefx.com/docs/houdini/expressions/pdgattribvals.html [www.sidefx.com]
it will just return the values of the attribute with the name given in the parenthesis. So for whatever work_item is currently processing it will return the value of "image" and use that to retrieve and insert the path to the image file that is to be zipped. The function he uses is a common command-line/terminal function; https://www.geeksforgeeks.org/zip-command-in-linux-with-examples/ [www.geeksforgeeks.org]
Hope this helps you out, cheers!
Technical VFX artist @ Housemarque / Sony Interactive Entertainment
- happybabywzy
- 86 posts
Robbert
Thank you , it very helpful to me
