Duplicate object on curve
793
4
1
citizen
May 10, 2023 10:56 p.m.
I want to duplicate an object on a curve's points and scale it using a ramp driven attr. I don't want to use the point numbers of the curve, but the points' locations on the curve (probably using curveu attr). How is this done in a wrangle if it's possible?
tamte
May 10, 2023 11:24 p.m.
you can use Chain SOP
Tomas Slancik FX Supervisor Method Studios, NY
citizen
May 10, 2023 11:38 p.m.
I did try the Chain SOP, but unfortunately the scaling works only on two axis.
Edited by citizen - May 10, 2023 23:38:55
Xue_Yue
May 11, 2023 4:24 a.m.
Hello, do you mean like this?
Here you can set whatever vector you want for the scaling. I used @curveu.
scale (@transform , set (@curveu ));
Edited by Xue_Yue - May 11, 2023 04:29:03
transform.hip (229.1 KB)
citizen
May 11, 2023 8:28 a.m.
Xue_Yue Hello, do you mean like this?Oh yeah, thanks a lot!
