How dose Is Finite VOP work?
What is the meaning for "infinite numbers or NANs"?
How dose "Is Finite" VOP work
727 4 1- happybabywzy
- 86 posts
- GOgraphR
- 67 posts
a NaN is Not a Number.
And infinity is that "8" that's laying lazy on its belly...
if you continue the series 1/x where x gets closer to zero like
even better: Try this in your python shell
a NaN is a number that is not defined at all. Like Inf-Inf=NaN.
But Inf+Inf=Inf
Then in math you have (in growing order)
and then there come vectors, matrices, and tensors... Don't ask ! Calculus !!
and then
Have a nice day !!
for (float i=1.0;i>0;i=i/10.0) print(1/x)
You'll get 1, 10,100,100,... 1e10 (meaning a 11 figure number) and eventually it will stop/throw with a +Inf for Infinity as a convention in math 1/0 is set as +Inf (Not 100% sure here, anybody??)even better: Try this in your python shell
i=1 while i>0: print(i, 1.0/i) i=i/10.0
But Inf+Inf=Inf
- Natural numbers like 1,2,3,4,5,... (There is some times a fighting if 0 (zero) belongs to the Naturals or not)
- Integers ...,-3,-2,-1,0,1,2,3,...
- Rational Numbers a/b where a and b are both integers (examples )1/1,1/2,1/3,-2/-1,2/-2,-2/3
- Real Numbers where the "rest" of numbers lives, like PI(3.14159....), e(2.718281828459045...)
- Complex numbers a+b*i , where i=sqrt(-1) ( Also called imaginary when a=0 )
pi and i run into each other at a cross roads.
i shouts at pi: "Get rational!!!"
pi responds: "Get Real!!!"
(Yes, I am one of those....)
and then
... where epsilon<0 ...
Have a nice day !!
Edited by GOgraphR - May 12, 2023 00:36:25
- tamte
- 8597 posts
within Houdini there can occasionally happen that you'll get Inf or NaN values typically on your geo or images after some SOP or COP operator, which can then cause errors in subsequent operators
those will literally show as NaN, Inf or -Inf in the Grometry spreadsheet or color info picker
so Is Finite, Is NAN VOP as well as isfinite(), isnan() VEX function allow you to detect these and potentially replace or process them
that being said, most of the operators have internal guardrails or in case of VEX some illegal operations have fallback values for such cases, like x/0 may return 0 instead of Inf or NaN
so if you notice any of the operators producing such values you should report a bug
Edited by tamte - May 12, 2023 01:27:31
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- happybabywzy
- 86 posts
GOgraphR
if you continue the series 1/x where x gets closer to zero likefor (float i=1.0;i>0;i=i/10.0) print(1/x)
even better: Try this in your python shelli=1 while i>0: print(i, 1.0/i) i=i/10.0
But Inf+Inf=Inf
and then there come vectors, matrices, and tensors... Don't ask ! Calculus !!pi and i run into each other at a cross roads. i shouts at pi: "Get rational!!!" pi responds: "Get Real!!!" (Yes, I am one of those....)
and then... where epsilon<0 ...
Have a nice day !!
Thank your for your detailed reply
- happybabywzy
- 86 posts
tamte
