I'm working on some path related workflows that involve a lot of boolean operations resulting in adjacent surfaces with a touching edge, and I'm having some trouble working out a smart way to fuse them.
For example, I have these two surfaces touching, one has booled the other so they are flush. They share an edge in space but are not actually connected.
After fusing the overlapping points and dividing the geo into triangles, we can see the connectivity. The surfaces are only connected at every other point. Surface B's new edge has points along it corresponding to surface A's edge, and they are fused together. Surface A's edge is unchanged, creating open edges where Surface B's points are.
The highlighted points are not connected, and the red lines draw the missing triangulation.
By adding some noise to the surface we can see the open edges.
The best solution IMO is to find a way to add points to surface A's edges where surface B's points are. I'm currently looking into a way to isolate the seam edge of surface B and splice it into surface A, so all the points from both surfaces along the seam are fused. If anyone has any tips I'd love to hear it.
Stitching together adjacent surfaces with different topo
968 3 0- badman
- 11 posts
- CYTE
- 685 posts
Without looking further into it. This polystitch hda came to my mind. Maybe it can do what you need:
Tech Art Challenge [www.sidefx.com]
Cheers
CYTE
Cheers
CYTE
- Aizatulin
- 480 posts
- badman
- 11 posts
