I made a vex script that takes the "Base Group" of a group sop and does magical things with it. Its in this format: p36-37-38 p12-13
My problem is when I create a group without using a group sop, I don't know how to get that string. For exemple, if I group points and I use the group promote sop to convert to edges, how can I get the string of it?
-Olivier
Get String of Edge Group like this: p36-37-38 p12-13
1069 4 1- olivierth
- 1007 posts
- Benyee
- 56 posts
In this situation I think you can try coding in vex like this for getting the string.
Hope this helps.
Hope this helps.
function int[] unique_elements(int arr_orig[]) { int arr[]=sort(arr_orig); for (int i=0;i<len(arr);i++) { while(arr[i]==arr[i+1]) pop(arr,i); } return arr; } function string[] get_uniq_elements(string array[]) { // int size=len(array); for(int i=0;i<size;i++) { for(int j=i+1;j<size;j++) { if(array[i]==array[j]) { array[i]==array[j]; for(int k=j;k<size-1;k++) { array[k]=array[k+1]; } size--; j--; } } } // string uniq_array[]; for(int i=0;i<size;i++) { push(uniq_array,array[i]); } return uniq_array; } //---------------------------------------------- // int tmp_pts[]=expandedgegroup(0,'ppp'); int pts[]=unique_elements(tmp_pts); //int nb_pts2[]; string edges[],edge; foreach(int pt;pts) { int nb_pts[]=neighbours(0,pt); for(int i=0;i<len(nb_pts);i++) { if(find(pts,nb_pts[i])>=0) { edge = sprintf("p%g-%g ", min(pt, nb_pts[i]), max(pt, nb_pts[i])); if (inedgegroup(0, "ppp", min(pt, nb_pts[i]), max(pt, nb_pts[i]))) push(edges,edge); } } } string edges2[]=get_uniq_elements(edges); printf("%d\n",len(edges2)); printf("-----------------\n"); string grp_edges=""; foreach(string cur_edge;edges2) { grp_edges+=cur_edge; } s@grp_edges=grp_edges;
Edited by Benyee - June 19, 2023 11:26:41
- tamte
- 8555 posts
you should be able to do just this in Detail wrangle
int pts[] = expandedgegroup(0,'edge_group'); string edge_strings[]; for(int i = 0; i < len(pts); i += 2) { append( edge_strings, sprintf("p%d-%d", pts[i], pts[i+1]) ); } s@edgegroup_string = join(edge_strings, " ");
Edited by tamte - June 19, 2023 15:47:33
FX Supervisor
Method Studios, NY
FX Supervisor
Method Studios, NY
- Benyee
- 56 posts
tamte
int pts = expandedgegroup(0,'edge_group');
string edge_strings;
append( edge_strings, sprintf("p%d-%d", pts, pts) );
Generally,the function “expandedgegroup” is handy and powerful, nice solution, thanks.
- olivierth
- 1007 posts
