I'm trying to edit a grid while looking through a camera in LOPS. The only solution I found was to LOP import the camera to obj level. Is there an easier/faster way to do it?
If I'm inside the sopcreate, the camera is not showing up, since it's downstream in LOPS (see screenshot leftside). When I plug the grid below the camera (right), Houdini crashes.
Thanks,
Luis
Edit SOP create while looking through a camera in LOPs
3273 4 2-
- luisguggenberger
- 14 posts
- mtucker
- 4566 posts
You could pin the Scene Viewer to the camera1 node, looking through that camera... The downside is that while you're in SOPs in the network editor, the viewer is still showing LOPs. So you can't use interactive SOP handles and there will be a performance penalty as the SOP geo will be re-imported to LOPs with every change you make to any SOP parms.
- luisguggenberger
- 14 posts
- eikonoklastes
- 448 posts
- Mohanpugaz
- 174 posts
Has anyone found other solution for this, Im still using the workaround mentioned above.
Mohan Pugaz
movfx
movfx
