I have a bunch of files on my hard drive. And I load this, do some operations, and want to save to USD using standard component builder with variant.
SO what I do. in component geometry I use file SOP. Which have reference parameter to "MYITERATION" from the loop node, hence it need to loop over all folders/files starting from 0 to 5 and add it to variant, but I have only 1 variant (var4) and var0 is empty.
Do I do something wrong or it bag with fileSOP? Houdini 19.5.640
Variants + component builder + fileSOP
1040 3 1- Hyperreal-Studios
- 15 posts
- Hyperreal-Studios
- 15 posts
- goldleaf
- 4168 posts
Instead of the For Block, try the Component Geometry Variants in "Number" mode, using the `@GEOVARIANTINDEX` context option.
https://www.sidefx.com/docs/houdini/nodes/lop/componentgeometryvariants.html#tips [www.sidefx.com]
I'm o.d.d.
- Hyperreal-Studios
- 15 posts
