Hey there,
I'm using chops to import music into my HIP
I'm able to play the music in the background with the timeline
but whenever I'm creating a Flipbook, I'm unable to hear the sound
Flipbook only allows files to be used as a background sound
Is there any way I can set my CHOP network as my flipbook sound automatically?
is there a way for chops to save an mp3 file? maybe then I'll be able to automatically cache and read it.
Flipbook with CHOP shound
552 1 1- Nitzan Tregerman
- 7 posts
- play_w_madness
- 9 posts
You can write chops to a .wav file using ROP Channel Output CHOP node, and then play that .wav as an audio file.
List of supported chop formats: https://www.sidefx.com/docs/houdini/io/formats/channel_formats.html [www.sidefx.com]
Also I would give a try using `op:/path/to/your/chop` syntax in the Audio Filename field.
Though I doubt that it will work, since mplay (the flipbook player) is a separate process from Houdini, so most likely it won't be aware of any nodes there.
Especially since the same mplay process can be used by multiple different Houdini processes simultaneously.
Edited by play_w_madness - Sept. 16, 2023 02:41:19
