Mops randomize rotation around the pivot not around centroid
   581   2   1
Like the title says... anybody knows why when using the Mops randomize rotation i can't force it to rotate the instances around the pivot. I move my instanced object away from the center of the scene on purpose so when randomizing the rotation is spreads around in a spherical fashion, but the mops randomize still rotate each object in local space around the centroid of each instance. Not quite sure why it does that.
A.
You need to use the Mops pivot node to change the pivot when using MOPs, if I recall correctly, then the randomize should work as you expect. If you want to visualize it, use the mops visualize frame
Edited by sepu - Oct. 4, 2023 21:51:29
I was not aware of that one. Thank you, it indeed does what i needed. I had cheated merging a point at the opposite position of my instanced geo, but this is way cleaner.
Cheers for that one,
A.
Edited by Adriano - Oct. 5, 2023 02:09:52
