I'm trying to sort the points on the curve using node SORT, but I don't see where the error is, but it just doesn't work. The curve is in motion. Thank you for your help
Sort scatter points on moving curve
442 2 0- chuchvalec
- 1 posts
- BabaJ
- 2041 posts
It's because at frame 53 and afterwards, you have points arcing downwards. You've defined your point order as the distance from location 0,-1, 0 - so those points are now nearer the other ones which are higher in y value.
You will have to devise an equation or some other method for sorting your point numbers - depending on what the entire range of your geometry will be doing.
Edited by BabaJ - Dec. 6, 2023 12:37:36
- animatrix_
- 4516 posts
You can freeze your animation using Timeshift SOP and then copy the point numbers by storing them as an attribute before the Timeshift.
youtube.com/@pragmaticvfx | patreon.com/animatrix | animatrix2k7.gumroad.com
