Redshift viewport texture uv’s
   405   1   1
I edited the default Redshift Material Vopnet so I can add an OpenGL texture like in this tutorial :
But very often I’m using multiple UV’s. So I was wondering if anyone knows how to add some kind of selection menu or input field to select a different uv map.
I’ve been fiddling around in he dark, but no luck so far.
toonafish
The uv viewport uv selection menu also changes which uv set is used for material visualization.
