VR camera in Solaris
   516   3   0
It is possible to use vrcamera in Solaris? I need to render a latlong left over/right under projection inside houdini.
Is there a way to do this in Solaris?
I have seen that using Physicallens shader you can render a polar projection, but I would need a stereoscopic one, possibly over/under.
Thank you very much for any suggestions
Paolo
If you're using Karma CPU, it's possible using VEX. Karma XPU has a fixed suite of lens shaders at the current time.
mark
I think the built-in VRLens shader works with Karma CPU, but I haven't tried all its various modes.
Thank you Mark and Jsmack.
VRLens shader works fine in Karma CPU.
Paolo
