I've got a piece of geometry that I've blasted from a model. I need to send it to the origin and zero out its rotations. I can send it to the origin, no problem. But, I can't seem to get the darn rotations to zero out. By "zero out" I mean the object is not rotated at the origin.
FYI: The object comes in pre-rotated...so I don't have a frame of reference (like a rest position) to work with.
Any ideas on how to achieve this?
Zero Out Object Rotations and Translations
2200 9 0-
- TheDude123
- 90 posts
- kodra
- 373 posts
- tamte
- 9383 posts
if it comes from alembic that was exported as a rotated object chances are it will contain transform as intrinsic
if the transform is already baked into geo for example from scan then you need to build reference frame yourself apart from Bounds sop you can build it from 3 points for example, origin, z and y
Edited by tamte - Feb. 3, 2024 08:19:21
- animatrix_
- 5100 posts
- jsmack
- 8177 posts
- TheDude123
- 90 posts
- jsmack
- 8177 posts
TheDude123jsmackhaha, nah...just need it at origin with 0 rotations so I can animated it easier.
All these methods are guesses based on the shape. if you need the true original orientation, you're SOL
I'll try the above methods from everyone.
Unless it's an fbx or alembic with a rotation on the object, it already has 0 rotations.
- Mike_A
- 392 posts
- TheDude123
- 90 posts
jsmackTheDude123jsmackhaha, nah...just need it at origin with 0 rotations so I can animated it easier.
Here is an example file...I can't seem to get it to work with the other methods...
- TheDude123
- 90 posts
