Hi guys,
this might be an obviously stupid question to many of you, but:
for a particle rain sim, I have 2 objects - object 1 and 2(ground). Particles first hit object 1, creates bounces/splashes, then I generate streams of particles off that that slide down. Some of the sliding particles slide off object 1 and then hit object 2.
How can I detect exactly which object is getting hit? I've tried to use the pop collision detect node and entered a specific path to the sop geo collision target in there, but that does not seem to work. If I turn on the color hits I can see that every hit, not just the collision target is getting colored...
What I ultimately want is to have some of the dripping particles (from obj 1 to obj 2) create collision events from where I can generate secondary splashes. How can I do this?
Thanks,
Dag
particle question: how to record secondary hits?
282 1 0- Dougie0047
- 63 posts
- Enivob
- 2537 posts
There are several hit attributes. (i@hitnum, @hittime)
https://www.sidefx.com/docs/houdini/nodes/dop/popcollisiondetect.html [www.sidefx.com]
Inside a popwrangle, try changing the color based on how many times a hit has occurred.
You could also add them to groups which could be used to spawn another stream.
https://www.sidefx.com/tutorials/particle-streams-1/ [www.sidefx.com]
if(i@hitnum>4){v@Cd = set(1,1,0);} if(i@hitnum>10){ v@Cd = set(0,1,0); i@group_green = 1; }
Edited by Enivob - March 2, 2024 17:57:43
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
