Sesi_temporary null replacing null ?
   344   3   1
Hello i accidentally replaced the defined sop/null with sesi_temporary::null
wich shows up above Sop/null wich is now in only to be found in the current Hip file.
This happend when i wanted to test what whould happen if i tried to add a scipt to a default node.
Does annyone know how to restore the default null ?
as well as remove the sesi_temporary::Sop/null (in tge internally defined operators.
(its shape and color changed icon stil the same and is listed in tab menu as null(digital asset)
Also i t seems now my attribute cleanup node is broken as the null REFERENCE node inside throws the error invalid source 0
(wich doesn`t make anny sense)
Hi, a look at cera's post here [www.sidefx.com] might solve your issue.
THX <3
