start scene starts from 1001 to 1240, I managed to find this video, where the people of Entagma explain it very well
https://www.youtube.com/watch?v=ejZtvwztceU&ab_channel=Entagma [www.youtube.com]
but the surprise has come when I manage to open the scene, but the timeline is as always from 1 to 240, does anyone know how to solve this?
thank you very much to all
start scene with changed frames
303 1 1- tulygraf
- 4 posts
- Enivob
- 2572 posts
You can run python code to customize Houdini on startup.
Create a "scripts" folder in side your Houdini 20.xxx folder and drop this code into a text file.
On my system, the file path is: C:\Users\Admin\Documents\houdini20.0
Save the text file with the exact name of "123.py" inside the scripts folder. Launch Houdini, and the code will run, setting your time line to the frame range.
Learn more about startup scripts here...
https://www.sidefx.com/docs/houdini/hom/locations.html [www.sidefx.com]
def main(): hou.playbar.setFrameRange(1001,1241) if __name__ == '__main__': main()
Edited by Enivob - May 14, 2024 08:46:26
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
