houdini 9 and 8 & suse 10.2+quadro fx4000 problem
7437
13
0
Sept. 28, 2007 4:19 p.m.
Ok im trying to run houdini 8 on suse 10.2 with quadro fx4000 and the UI looks weird. can anyone help?
Sept. 28, 2007 4:21 p.m.
And also i'm having problems with houdini 9.730,when i move around the viewport the movement looks jittery,like a low framerate.And also the documentation has a problem.It won't load.
Sept. 28, 2007 4:22 p.m.
help? :?: :shock:
Joe
Sept. 28, 2007 4:30 p.m.
The Houdini 8 problem looks like something that was solved in Houdini 8.1 and 8.2. Are you using the latest Houdini 8.2? I'm not sure what would cause the 9 problems, though.
Sept. 28, 2007 4:34 p.m.
im using a later build 8.0.308 or something like that,ill try and download the latest build and see if that could fix the problem. i really don't know why the docs would create the problem. take a look:
Sept. 28, 2007 4:37 p.m.
and can you please tell me which drivers to use to remove the houdini 9 orbit problem?
Joe
Sept. 28, 2007 4:50 p.m.
Please download the latest build of Houdini 9, too – I think those documentation bugs have been fixed. I don't know that I can recommend a particular driver to you, though – I don't have that card. Others may be able to help.
Sept. 28, 2007 4:59 p.m.
ok thanx
wolfwood
Sept. 28, 2007 5 p.m.
I like 1.0-9629 I've had nothing but problems with the 100 series.
Sept. 28, 2007 5:03 p.m.
ok these are the drivers that i've tested so far and they all give the same result: 96.29 96.31 100.x.x
wolfwood
Sept. 28, 2007 7:07 p.m.
Which Houdini distro you using? gcc 4.1? or gcc3.4? (I recommend 3.4)
Sept. 28, 2007 7:27 p.m.
gcc 4.1 you reccomend 3.4? can i run it on suse10.2?
wolfwood
Sept. 28, 2007 8:59 p.m.
Assuming its 32-bit SuSE 10.2 then yes, 3.4 will work. I tried the 4.1 Ubuntu version on SuSE 10.2 and I had all sorts of trouble with the help too.
Sept. 29, 2007 11:28 a.m.
thanx man the different gcc worked as well as the new 8 build. but im still having problems with help. it must be my linux libs.
