ocean wave
   4952   10   2
Hi, greetings
I'm trying to make a model just like gif file bellow, making the waves is easy and I have no problem with it but I don't know how to make flat part in gradient way.
I'll be thankful if you help me for making this model.
Edited by moritz-h86 - 2022年1月17日 23:06:30
ocean waves.gif (5.3 MB)
There is a vex function called lerp(). Basically you group half of the area and mix in the displacement points for the group.
Edited by Enivob - 2022年1月18日 09:37:30
ap_half-wave_tube.hiplc (185.2 KB)
Using Houdini Indie 20.5
nVidia 3060RTX 12BG RAM.
Or, you can make a simple volume box, and ramp it's density along that axis.
You can plug it into the ocean setup, and it uses it as a mask to mult down the effect.
Very handy way of fading down the waves naturally as it's multing down the spectrums.
Ooh you may be doing like above, just using the mountain or a noise.
You can make a wrangle that takes the relative bounding box of the axis your water is traveling down,
and use that in a ramp, then you have freedom to adjust the falloff.
Also easily doable without any VEX needed
Edited by eikonoklastes - 2022年1月20日 05:32:16
Indeed, well, it's still using VEX 100% inside though isn't it hehehe.
tinyhawkus
Undeniably. But Houdini is ultimately being compiled into machine code, and yet here we are, clicking on screen, like a bunch of animals...
The new suite of attrib SOPs are great, really removes the need to get dirty with VEX.
eikonoklastes
tinyhawkus
Thank you for replying, can you please share the script? it's not working for me, I followed your instruction and didn't work, there is properly something wrong with my model.
moritz-h86
Sure thing. Here's a scene, attached below.
And if you need to quickly see what was changed in a node, you can always click the Search and Filter button, and choose Parameters with Non-Default Values:
Edited by eikonoklastes - 2022年1月24日 01:27:13
Noise Mask.hiplc (199.6 KB)
eikonoklastes
Thanks! I didn't notice this button. Very useful.
