It seems that the bicycle gear chain can't be implemented in
   2907   18   5
Hi, guys, how are you?
I want to make a rig to rotate a bicycle chain,
but my brain doesn't seem very smart, and I've almost lost all my hair thinking about it! The curve's CU can't be greater than 1 either. Guys, give me some constructive advice.
Thanks, wish you all great wealth and promotions with salary increases.
Here's my quick attempt at a solution. I'll upload another version using a more practical example when I get around to it.
apex_chain_v002.hiplc (442.9 KB)
AntonMoss
You’re literally a genius. This is amazing! Please take my knees. You blow me away.
Here is a version using SOPs.
chain_animation.hip (1.2 MB)
Konstantin Magnus
Thanks, this method is also very good and creative. But it doesn't seem to be Apex, yet it's still impressive. Great rig, this technique is a light of humanity. You are the best.
Konstantin Magnus
This is cool! Fantastic use of copernicus sdf's and the trace sop. Time to study this wrangle.
Edited by AntonMoss - 2026年6月12日 18:18:34
AntonMoss
Konstantin Magnus
Glad you like it. Here is a breakdown of the wrangle:
// PARAMETER
float speed = chf('speed');
//A multiplier float parameter to adjust the speed of the movement.
// UVW
int num = nuniqueval(0, 'prim', 'copynum');
// The total number of individual integer values of the copynum-attribute.
float u = i@copynum / (num - 1.0);
// Division of the copy number by the total number of copies, effectively creating a float ranging from 0.0 to 1.0 across all copies so each copy gets offset along the curve later.
v@Cd = set(u, 1.0 - u, 0.0);
// Visualization of u ranging from green to red.
// OFFSET
u = (u + @Time * speed) % 1.0;
// offsets u by the current time multiplied by speed. the modulo operator sets values above 1.0 back to its remainder. eg. 1.05 turns into 0.05
// CURVE ATTRIBUTES
vector uvw = set(u, 0.0, 0.0);
vector pos = primuv(1, 'P', 0, uvw);
vector nml = primuv(1, 'N', 0, uvw);
vector up = primuv(1, 'up', 0, uvw);
//The u float value becomes part of the vector uvw to look up position, normals, and up vectors from the curve on the second input.
// TRANSFORMATION
matrix xform = maketransform(up, nml, pos);
setpackedtransform(0, i@primnum, xform);
// Converting these three vectors into a transformation matrix that gets applied to the packed chain elements.
Edited by Konstantin Magnus - 2026年6月13日 06:01:58
It's not APEX, but couldn't this be done simply with the Chain SOP?
AntonMoss
Really looking forward to it when you have time to upload your other version.
guoli
AntonMoss
Here's a far better solution. I still have to clean up the file and upload it later today.
AntonMoss
guoli
AntonMoss
Really looking forward to your masterpiece
As promised. I've attached the needed subgraph and component you'll need for this to work, along with the hip file.
Edited by AntonMoss - 2026年7月2日 03:27:28
apex_chain.zip (9.1 MB)
Hi. Im following this thread.
I have grabbed your zip file. If I view your am_chain node the chain vanishes. Does your am_chain.2.0.bgeo need to be copied somewhere (i'm guessing that is the issue).
Best. Mark
Screenshot 2026-07-02 083951.jpg (346.8 KB)
Mark Wallman
Best. Mark
Yes, make sure you copy the folders, apexcomponent and apexgraph, and put those in your $HOME directory for houdini. Windows - C:\Users\Username\Documents\houdiniX.Y
Edited by AntonMoss - 2026年7月2日 05:19:54
thanks!
AntonMoss
AntonMoss
AntonMoss
Wow, you're amazing!!! I can't express my gratitude to you in words!
You’re really awesome, thank you!!!
AntonMoss
Mark Wallman
Best. Mark
Hello, esteemed expert! I have a request. Is it possible to make a version where the nodes are built-in, so there's no need for the extra method of copying those two ApexGraph files externally, but instead use internal nodes or have it built directly into the software?
Sorry if this is offensive, and thank you, respected expert.
Edited by guoli - 2026年11月21日 01:36:50
That's not offensive at all. I haven't looked at this in a bit, but I'm sure there's a way. I'll try to upload a file this week without the need for external files.
AntonMoss
Your skills are really impressive, really looking forward to the simple version, thanks
