PDG/TOPs » PDG Running On GPU cores
By Dav_Rod,
- 1
- 2955
By kenxu
Technical Discussion » Grains colliding with moving object not working.
By Dav_Rod,
- 2
- 2636
By Dav_Rod
Technical Discussion » Explain SOP Solver dynamics node
By Dav_Rod,
- 0
- 821
By Dav_Rod
Houdini Indie and Apprentice » Introduce geo into DOPNET at different frames (dopnet impulse activation with an expression?)
By Dav_Rod,
- 2
- 1535
By Andr
Technical Discussion » impulse birth rate
By circusmonkey,
- 9
- 10312
By Dav_Rod
Houdini Indie and Apprentice » opencl Vellum Houdini 17
By Dav_Rod,
- 2
- 1954
By Thingy1972
Houdini Indie and Apprentice » Move the broken pieces to a point.
By Dav_Rod,
- 2
- 1194
By Dav_Rod
Technical Discussion » Creep over a Polygonal Surface
By fxrod,
- 7
- 6054
By Efi
Houdini Indie and Apprentice » Using Creep Node with complex and irregular surfaces.
By Dav_Rod,
- 0
- 1091
By Dav_Rod
Houdini Lounge » Cusp Normals
By pip31,
- 6
- 5361
By Konstantin Magnus
Houdini Lounge » How to group by filter expression in Houdini 16 using "$CR>".
By chrissweeny,
- 6
- 6478
By BabaJ
Houdini Indie and Apprentice » Particles on surface with volumesample and volumegradient.
By Dav_Rod,
- 3
- 1554
By Dav_Rod
Houdini Indie and Apprentice » The characters [ and { can not be typed.
By Dav_Rod,
- 2
- 1419
By jsmack
Houdini Indie and Apprentice » Access from one node the attribute from another node.
By Dav_Rod,
- 2
- 1828
By Dav_Rod
Houdini Indie and Apprentice » addpoint VEX function malfunction?
By Dav_Rod,
- 7
- 2528
By BabaJ
Houdini Indie and Apprentice » Convert a string array into an integer array
By Dav_Rod,
- 4
- 4314
By Dav_Rod
Houdini Indie and Apprentice » Look At VOP node
By Dav_Rod,
- 11
- 3723
By Dav_Rod
Technical Discussion » Can you share a single indie license across 2 computers/clients?
By RodrigoSalazar,
- 3
- 3087
By bobc4d
Houdini Learning Materials » PScale controlled with ramp node
By Calebos,
- 4
- 13058
By Dav_Rod
Technical Discussion » Copying primitives attached to one distribution of points... to another distribution of points.
By Dav_Rod,
- 0
- 890
By Dav_Rod
