Hi wondering what the load procedure is for houdini.pref.
how can I set certain preferences for all licenses on the
network, and still allow users to have some semblance of
customizing their own preferences…
I tried creating a houdini.pref.nosave to setup values for
our external help server. But then noticed as a result of
this file, i was unable to save personal preferences such
as pane coloration, startup desktop, etc…
Do all houdini.pref get read in the path? which order?
does the final one read trump any previously set prefs,
or is it more like the first one read is used and the
any subsequent houdini.pref are ignored…
I then renamed houdini.pref.nosave to houdini.pref and
got back my pane coloration and startup desktop… but
lost the facility wide houdini.prefs that setup the
external help server port
thanks!
houdini.pref
13497 13 1- sdugaro
- 380 posts
- sdugaro
- 380 posts
got this working with the help of jlait + the docs. cheers!
1) you need to define the $HSITE environment variable
2) the $HSTIE environment path must have (end with ?) houdini10.0.
3) create a houdini.pref.nosave in $HSITE
4) the first line of the file should contain the following directive to pull in user preferences
#include $USER/houdini10.0/houdini.pref
5) override those user preferences later in the file with site wide preferences
general.panecoloring.val := 1;
misc.useexternalhelp.val := 1;
misc.externalhelpurl.val := "http://italy:5050 [italy]";
- sdugaro
- 380 posts
spoke too soon, that directive doesnt work. when i
#include $HOME/houdini10.0/houdini.pref
which exists.. i get the following error when houdini loads instead.
cpp error: “houdini.pref”:1 Unable to include /net/homedirs/sdugaro/houdini10.0/houdini.pref
it looks as if its found, (and it does exist, unlike the prev path)
but has a problem with it. my $HOME/houdini10.0/houdini.pref
seems to load find on its own… any ideas?
- sdugaro
- 380 posts
ok, got this working.
The value of the include directive must be in quotes to avert the cpp error.
the $HSITE houdini.pref also needs to be a houdini.pref.nosave in order
to overrides the included user options. else the last houdini.pref in the
path will win (in my case the user houdini.pref)
Turns out that having an $HSITE variable isn't a requirement.
You just need a houdini.pref.nosave to be found at the top
of the list of paths in $HOUDINI_PATH. The first houdini.pref.nosave
encountered is the one read and all subsequent houdini.pref(.nosave)'s
are ignored.
So in summary, #include “$HOME/houdini10.0/houdini.pref” in the first line
of a houdini.pref.nosave then override some houdini.pref with site prefs
and ensure that this houdini.pref.nosave is at the top of your $HOUDINI_PATH.
are ignored.
- wolfwood
- 4262 posts
- sdugaro
- 380 posts
cool, glad to see a posting of mine having the potential to be put to some good use!
you might also try to define an environment variable ($HVER) when houdini loads
so that you dont need to hardcode the houdini10.0 in the houdini.pref.nosave
(#include “$HOME/houdini$HVER/houdini.pref”)
You might not want to force the user to use his houdini10.0 options when
using a different version of houdini (ie. $HOME/houdini10.5/houdini.pref)
since its possible that the houdini prefs and values could be different.
- amilne
- 7 posts
This has been very helpful! I've been trying to do something similar, but I've run into a few problems.
We want a site-wide setting to disable the “Open Help Browser at Startup”. This setting is in hcommon.pref I tried creating a hcommon.pref.nosave containing
#include “$HOME/houdini10.0/hcommon.pref”
startupHelp := 0;
And then I put the directory containing this hcommon.pref.nosave in the front of the HOUDINI_PATH. This all works fine, except that now if I change any of my preferences in Houdini which would go in the hcommon.pref file, it doesn't save them to my $HOME/houdini10.0/hcommon.pref anymore. This is no good if the user can't save any of their other preferences. Did you run into this?
Also, we wanted to change some display settings which are found in display.pref. This file seems to be a different format and I can't get it to work. I put the following in display.pref.nosave, but it never seems to get picked up:
#include “$HOME/houdini10.0/display.pref”
near ( 10 )
far ( 1000000 )
adjustlimits ( 0 )
I put the display.pref.nosave in the same location as the hcommon.pref.nosave, which does get picked up.
startupHelp := 0;
near ( 10 )
far ( 1000000 )
adjustlimits ( 0 )
- fxrod
- 133 posts
When you say you need to add the houdini.pref.nosave to the ‘top of the Houdini path’, do you mean at the beginning or the end?
My path structure is like this.
<user>:<shot>:<show>:<site>
If I add the .nosave to the <site> would this not work?
Francisco Rodriguez
Effects Animator | Walt Disney Animation Studios
- fxrod
- 133 posts
- Allegro
- 696 posts
So since I just had some confusion with this myself, here's a bit more detail for the next person who comes along:
- In a Houdini Shell, if you use “hconfig -ap” you'll see the priority of the HOUDINI_PATH.
- By default, when you add an HSITE variable, it will be placed in priority after the user prefs. This means that as long as there is no houdini.pref file in their home directory the HSITE preferences will take over… but once there's a file in their home… you can't force anything on them.
- If there is one preference you want to force, then you'll need to manually set the HSITE to come first in the priority by building the HOUDINI_PATH yourself.
- If you leave it as houdini.pref in your HSITE, then users can save preferences however they want (but the one or two you've specified will overwrite theirs)
- If you leave it as houdini.pref.nosave, then users may not edit any preferences
Stephen Tucker
VFXTD
VFXTD
- mheberlein
- 6 posts
Thank you, everyone! With your information, I was able to
Now there's only one issue remaining: I'd like to replace
- create a
houdini.pref
(not.nosave
) file in a plugin - make sure it's positioned first in
HOUDINI_PATH
- include the user preferences via
#include “$HOME/houdini16.5/houdini.pref”
16.5
with a variable but $HVER
(from sdugaro's example) isn't working for me. Maybe that's a custom variable? I found HOUDINI_VERSION
but that's the long format (e.g. 17.0.337 instead of 17.0). Any tips?
Edited by mheberlein - Sept. 20, 2018 13:53:54
- tarjun
- 20 posts
I have my files structured as below
and the data in colors.pref.nosave is as below
I first export HOUDINI_PATH as
Now when I launch houdini I get the following error
am using houdini-16.5.323, anyone has any idea what's this issue, I tried with removing the file name suffix of .nosave
> [test_houdini_settings]$ tree . └── houdini16.5 └── colors.pref.nosave
ui.render.val := 1; ui.flipbook.val := 1; ui.imageview.val := 1; ui.saveimage.val := 1; ui.view3d.val := 1; ui.renderstate.val := 1; ui.swatch.val := 1; ui.cc.gamma.val := 1; ui.cc.lut.val := "/scratch/custom_aces.lut";
export HOUDINI_PATH=/scratch/test_houdini_settings/houdini16.5
Could not find scene mouse modifier file: SceneMouseModifiers Unrecognized modifier key token: scene.handle.floor.mirror Unrecognized modifier key token: scene.handle.common.scale_delta Unrecognized modifier key token: scene.selector.plane.fullspec.pick_normal Unrecognized modifier key token: scene.selector.plane.quickspec.align_only Unrecognized modifier key token: scene.selector.plane.quickspec.move_only Unrecognized modifier key token: scene.selector.plane.quickspec.point_at Unrecognized modifier key token: scene.floor.xy Unrecognized modifier key token: scene.floor.h Unrecognized modifier key token: scene.common.extend Unrecognized modifier key token: scene.handle.bbox.mirror Unrecognized modifier key token: scene.handle.bbox.uniform Unrecognized modifier key token: scene.handle.crosshair.scope Unrecognized modifier key token: scene.handle.crop.mirror Unrecognized modifier key token: scene.handle.crop.restrict Unrecognized modifier key token: scene.handle.domain.mirror Unrecognized modifier key token: scene.handle.domain.copy Unrecognized modifier key token: scene.handle.hose.group Unrecognized modifier key token: scene.handle.hose.uniform Unrecognized modifier key token: scene.handle.ikpivot.lock_click Unrecognized modifier key token: scene.handle.isosegment.extend Unrecognized modifier key token: scene.handle.pill.mirror Unrecognized modifier key token: scene.handle.slider.mode Unrecognized modifier key token: scene.handle.motionpath.insert Unrecognized modifier key token: scene.handle.motionpath.delete Unrecognized modifier key token: scene.handle.motionpath.move_key Unrecognized modifier key token: scene.handle.mousewheelbump.slow Unrecognized modifier key token: scene.handle.mousewheelbump.fast Unrecognized modifier key token: scene.handle.mousewheelradius.slow Unrecognized modifier key token: scene.state.brush.brush_radius Unrecognized modifier key token: scene.state.brush.brush_radius_wheel_slow Unrecognized modifier key token: scene.state.brush.stencil_clear Unrecognized modifier key token: scene.state.capturelayerpaint.select Unrecognized modifier key token: scene.state.edit.brush_radius Unrecognized modifier key token: scene.state.edit.brush_radius_wheel_slow Unrecognized modifier key token: scene.selector.join.flip_click Unrecognized modifier key token: scene.state.stroke.cursor_radius Unrecognized modifier key token: scene.state.stroke.cursor_radius_wheel_slow Unrecognized modifier key token: scene.selector.uvpelt.hint_click Unrecognized modifier key token: scene.state.bone_create.split Unrecognized modifier key token: scene.state.bone_create.parent Unrecognized modifier key token: scene.state.capture_weights.bone_toggle ERROR: Couldn't open resource file "resources" (No such file or directory) Can't open dophints.cmd Could not initialize the help server: Traceback (most recent call last): File "<stdin>", line 1, in <module> ImportError: No module named houdinihelp ERROR: Couldn't find 'SI_ColorEditor.ui' for reading. Looked in: /scratch/test_houdini_settings/houdini16.5/config/Applications
Edited by tarjun - Sept. 25, 2018 15:03:10
- 7812 posts
tarjun
Yeah, that doesn't include the install directory.
I think you want
HOUDINI_PATH='/scratch/test_houdini_settings/houdini16.5:&:'
so that the houdini directory is still searched.Also, the preferred way to set the viewer LUT is with
HOUDINI_IMAGE_DISPLAY_LUT='/path/to/viewer.lut'
, rather than messing with nosave prefs.
Edited by jsmack - Sept. 25, 2018 16:19:37
- tarjun
- 20 posts
