How to !
17400 21 6- circusmonkey
- 2624 posts
Just thought I would share some of my solutions to common issues that pop up for users. I have so many files now on my laptop it would be shame to throw them away without sharing the knowledge I have gained from asking questions and doing work.
Scene attached shows how to make a ID pass with instanced objects, use the inspection tool in Mplay to read the point number.
The scene also shows how to override the dif color per instance via the creation of an attribute based on the point colour. The overridden colour is then rendered as a image plane. Any questions feel free to ask.
Rob
Rob
Edited by - June 16, 2013 02:07:23
Gone fishing
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- rafaels
- 696 posts
Thanks a lot, Rob!
I'll pin this thread in my bookmarks now…
Toronto - ON
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
Create useful vector attributes from point. You might get given a bunch of points with just velocity and then have a task to adjust them. That means needing some basic attributes this set up shows you how to generate. N , v , up , id and use a very simple vop sop to generate a new up vector that's perpendicular to N.
Gone fishing
- zachlewis
- 45 posts
ah, the ol' double-crosser technique
thanks for posting these… honestly, I think handy VOPs workflows and tricks is one of the most exciting parts about learning Houdini. You apply the same concepts in so many different contexts… maybe as a minimalist piece / challenge to myself, I'll take one simple idea in VOPs and apply it again and again, in POPs, COPs, DOPs… variations on an algorithm for 8 contexts.
I'll have to give that some serious thought.
Well, thanks, it's been inspirational!
I'll see if I can post some handy-dandy, casual VOPs stuff too.
- circusmonkey
- 2624 posts
Technique: - This scene shows you a smart way of getting the transform and rotations data from an asset > The point generated has N and up that matches your geometry asset. That asset could of come from maya or another dept in your pipeline> Very handy
Note the point is at world zero and I invert the transform on the object merge node.
Rob
Rob
Gone fishing
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
Technique :- Object merge sop very handy but often you want to merge more than one stream of data and even better just plug your data in and merge. This scene shows how you can get the multi parm block from the object merge sop upto the top level of your tool , where you can just plug in your data and go.
/obj/`opinput(“.”,int(strreplace($CH,“objpath”,“”)-1))`/OUT
The above expression will evaluate the input and resolve a path. The “strreplace” part strips out the name of the parameter and leaves the number so you can count the inputs , 1 , 2 , 3 , 4 etc etc . The technique can be expanded to do all sorts of things.
Rob
Rob
Gone fishing
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
- cameradude
- 12 posts
- circusmonkey
- 2624 posts
You really want to watch this
http://www.sidefx.com/index.php?option=com_content&task=view&id=2512&Itemid=132 [sidefx.com]
Then maybe start a new thread with your questions.
Rob
Rob
Gone fishing
- cameradude
- 12 posts
Good stuff from Ari, I'm working through that now, along with a vex fractal tutorial.
I found this as well: http://www.sidefx.com/index.php?option=com_content&task=view&id=1744&Itemid=166 [sidefx.com]
Your examples also helped me learn by studying the vops nets…just hoping you'll post more.
Thanks again!
Thanks again!
- circusmonkey
- 2624 posts
Technique:- Use a texture projection sop from the camera to drive points as members of a group using the following expression
$MAPU >= 0 && $MAPU <=1 && $MAPV >=0 && $MAPV <=1 && $MAPW = 0 && $MAPW <=1
Then in vops move the points to prove the group is working. Can be used for all sorts of things like to define the birth of points from geometry only when the camera is looking at the subject matter.
Rob
Rob
Gone fishing
- hanton
- 36 posts
