OctaneRender for Houdini development preview
34865 65 7- juanjgon
- 83 posts
- juanjgon
- 83 posts
- Konstantin Kovalenko
- 33 posts
hi juanjgon
maybe you can help me) i dont know why, but octane dont want to work on my pc win 8 and give this error (see image)
but on my home pc it work is fine, i try everything ((
i have shelf octane, but i dont have any node octane
I did everything according to instructions
http://render.otoy.com/universe.php#38Installing%20Octane%20for%20Houdini [render.otoy.com]
write all this environment variable, move folder with octane in Document with houdini.env file, reinstall python 2.7.10, reinstall Visual Studio, nothing helps..
i dont want to reinstall windows (((
- juanjgon
- 83 posts
hi juanjgon
What GPUs do you have?
Do you have your NVidia drivers updated?
Also be sure that you are using the correct Houdini build that match the plugin build.
You should also test the Standalone application, if the Octane Standalone applications works, then the problem is the plugin, but if it doesn't work, then the problem can be the drivers or other issue in the system.
-Juanjo
Computer Graphics Software Developer
- 33 posts
- 33 posts
