Making architectural components of a building (Vaults, columns and more)
7908 23 2- Josep Lluis Fita
- 21 posts
- BabaJ
- 2042 posts
- Josep Lluis Fita
- 21 posts
- Konstantin Magnus
- 670 posts
Hi Josep,
architectural components are defined by mathematical formulas. So wrangles and VOPs might become your most effective tool for creating shapes inside Houdini.
Here is an example on turning a flat box into a vault roof:
vector bbox = abs(sin(relbbox(0, @P) * $PI * 4)); @P.y += max(bbox.x, bbox.z) * @Time;
Edited by Konstantin Magnus - Dec. 14, 2016 20:06:23
- BabaJ
- 2042 posts
Hey Josep,
Just saw what appears to be 3 new tutorials listed in the Houdini tutorial section that I thought might be of interest to you.
They are titled “Procedural Lake Houses”.
They are paid tutorials, but might cover more elements that you can apply to your project than other tutorials.
Edited by BabaJ - Dec. 15, 2016 11:26:06
- Josep Lluis Fita
- 21 posts
- matthias_k
- 483 posts
- Josep Lluis Fita
- 21 posts
- Josep Lluis Fita
- 21 posts
- Josep Lluis Fita
- 21 posts
I have found a tutorial of making columns for those who are interested in the architectural subject.
https://www.youtube.com/watch?v=O-D9w75tAas&t=2154s [youtube.com]
Bye
Bye
- matthias_k
- 483 posts
Another approach for the top/bottom rondings for the insets ;-)
and a basid gothic arc, but if you have komplex gothic window interior,
and you need an eaxct match, the you can build it in a cad program
or import illustrator path.
But depends on what program you are most familar with, to build the basic shapes.
It is possible to do it all in Houdini to be procedural ;-)
Edited by matthias_k - Jan. 3, 2017 07:33:53
- Josep Lluis Fita
- 21 posts
- Konstantin Magnus
- 670 posts
Josep Lluis Fita
for detailed windows of gothic period, is suitable building these through Houdini or is much more suitable import these from another software like maya?
That depends on whether you want to model it procedurally (Houdini) or by hand (Modo etc.).
- matthias_k
- 483 posts
Basic Example with trace, curve sect and skin nodes.
Houdini has a sculpt node, too.
I totally agree with Konstantin :-)
Procedural or not is the question.
Ray Example added… to many possibilties in Houdini ;-)
Edited by matthias_k - Jan. 4, 2017 17:04:45
- matthias_k
- 483 posts
Or maybe the most coolest I've ever seen:
http://www.ryanmcamis.com/index/#/new-gallery/ [ryanmcamis.com]
and than scan it :-)
Edited by matthias_k - Jan. 4, 2017 17:13:50
- Josep Lluis Fita
- 21 posts
- matthias_k
- 483 posts
- matthias_k
- 483 posts
Here's my solution,
should generate clear fully closed geometry.
The advantage is that you can render this one as “Subdivision”.
Top and bottom build with L-Systems ;-)
If put your model parts in HDAs, then you can reuse them easier.
And you can add features, which are then accessible in all files,
where you use your HDAs.
https://vimeo.com/86717911 [vimeo.com]
Edited by matthias_k - Jan. 14, 2017 09:57:00
- Konstantin Magnus
- 670 posts
For a pillar you can also use a tube with quadratic primitives, turn on subdivision and let a displacement shader do the details.
I attached a proof of concept
- matthias_k
- 483 posts
If you rotate the UVs, then that's good for screws, too.
https://www.sidefx.com/forum/topic/17423/#post-162935 [sidefx.com]
