I noticed that the box primitive have different point normals between 15.5 and 16. Is that normal? and if so, why did it change?
Thank you.
Different Point Normals in box primitive between 15.5 and 16
2585 9 0- uuLLFA
- 90 posts
- BabaJ
- 2048 posts
What your looking at in 16 are not point normals but vertex normals.
I can't say more as to why, but I was just playing with 15.5 and 16 and the display behaviour is different between the two.
If you go to display options ( if you haven't already )…you can check off/on for point, prim and vertex normals.
It seems in 15.5, you only get vertex normals if the box has the add vertex normals checked off. In 16 it doesn't matter, you can display vertex normals whether that check box is ticked or not.
But then again, in 15.5 if you look at the spreadsheet or middlemouse click the box, there are no point normal attributes; But you can still display point normals on or off.
In 16 I just put a wrangle after the box with @P = @N; Then I was able to get the point normals displaying like what you have with 15.5
- 7846 posts
Under display options, you can switch the automatically generated normals between vertex and point, as well as set the cusping angle for vertex normals.
http://www.sidefx.com/docs/houdini/ref/windows/displayopts_3d#normals [sidefx.com]
Edit:
keep in mind that this is simply the viewport display. Mantra provides similar control over automatically-generated vertex normals, but with more granular control over which objects have what type of normals generated. Fortunately, I believe the default is the same for both. Some mesh types are not subject to auto-cusping, such as non-polygonal types and polysoup primitives with fused vertices.
Edit:
Edited by jsmack - April 1, 2017 02:39:25
- BabaJ
- 2048 posts
Yeah..but to me the question was why the difference between the two.
Both have the display tick options for all three normals - point, prim, vertex.
But looking a bit more, with your tip about cusp angles…In the geometry tab (H16) under normals section there is a choice between which normal to auto-generate ( point or vertex ). Setting it to point gives the same display behaviour as H15.5
The normals section under geometry tab in H16 isn't in H15.5.
So I guesss the default in H15.5 was to auto-generate point-normals. And opening a new H16 file I see auto-generate is set to default for vertex.
Looks like this is the reason the OP is seeing a difference for the same Box.
Edited by BabaJ - April 1, 2017 13:21:57
- edward
- 7760 posts
- 7846 posts
- edward
- 7760 posts
- 7846 posts
edward
If you click on Save as defaults in the Display Options, I thought that saved to your ~/houdiniX.Y? I think this only determines the default for new scenes though.
I don't like saving the display options as defaults, because it saves every setting. I don't want color correction or background images to be saved into the defaults. Because that's only for the viewport preference, how do I go about altering a render property default?
- malexander
- 5169 posts
- 7846 posts
