This might be a ridiculously simple question - how do I display/visualize reversed/flipped normals in the viewport? Displaying primitive normals doesn't provide much feedback in complex geometry, it's easy to miss stuff.
Numerous searches in the forums/documentation came up empty.
Display reversed normals?
8630 10 1- stu
- 246 posts
- malexander
- 5158 posts
If they're auto-generated normals you can turn on Backface Culling (Optimization tab) and it'll remove all incorrectly wound polygons. If the normals are defined by an attribute, you'd have to write an attrib wrangle which compares the face and point/vert normal and assigns Cd = {1, 0 ,0} if dot(faceN, N) < 0.
- peteski
- 517 posts
Not sure if this is what you are looking for but you could turn on remove backfsces in the optimize tab of the display options (press d in the viewport in case you don't already know)
That might make it a bit easier??
http://www.sidefx.com/docs/houdini/ref/windows/displayopts_3d#optimize-tab [sidefx.com]
- stu
- 246 posts
- stu
- 246 posts
- peteski
- 517 posts
- stu
- 246 posts
- peteski
- 517 posts
- 8555 posts
- stu
- 246 posts
- tas3d
- 120 posts
twod
would you mind elaborating or making an example how to do this?
Im not sure if I got ur method right.
Michal Tas Maciejewski @ www.vfxtricks.com
