Hi All,
I have imported my mesh for my character.
I click on the New Autorig Asset button and fill out the form that pops up.
When I click Create a python script crashes and no autorig is generated.
Using H16.0557.
[SOLVED] AutoRig Script Crash?
1879 6 0- Enivob
- 2558 posts
- goldfarb
- 3455 posts
- Enivob
- 2558 posts
- goldfarb
- 3455 posts
- Enivob
- 2558 posts
I have tried different builds and I did the old trick of deleting the Houdini16.0 folder in My Documents. When you re-launch Houdini is a fresh new install again.
But the problem persists. The problem is in the python code itself.
Do you know what causes the “Couldn't add operator type error”? That is the key to the problem. Because the code has no checks to see if it successfully created a new operator, then it blindly continues on and tries to assign an icon to a None based object.
What do I need to change on my system to allow the creation of operators?
Edited by Enivob - May 3, 2017 09:45:55
Using Houdini Indie 20.0
nVidia 3050RTX 8BG RAM.
- goldfarb
- 3455 posts
- Enivob
- 2558 posts
