Anyone know why I might not be able to access the group sop?
Everytime I use the Tab menu or select from the menu, it defaults to group create node.
Unable to get group sop
3087 7 1- BabaJ
- 2042 posts
- galagast
- 252 posts
Group SOPs seems to be currently being deprecated..
There's a line (163) in the $HFS/houdini/OPcustomize the tells it to use a “Group Create SOP” whenever creating a “Group SOP”.
You can still however create one using the texport. Just navigate to your network and type this:
Or via python (assuming you have a geo1 object):
I do kinda miss the old Group SOP mainly because I'm so used to it (and it's sort of an all in one node).
opadd group
hou.node('obj/geo1').createNode('group')
- BabaJ
- 2042 posts
Hi galagast,
I was trying to follow an example of using a bounding object for grouping. Which is why I was trying to get the ‘old’ group sop.
But looking at the different new goup nodes again this morning I found if I click on the group creates' “Keep In Bounding Regions” option, you get more expanded controls, like with the ‘old’ group sop.
But your tip on how to get to the old one is appreciated.
At least I now know that it's not a bug and working as intended.
The example the guy was doing was with H16, so I assumed it was readily available since I could also see it in the menu in my file too.
Thank you.
Thank you.
- 7814 posts
- galagast
- 252 posts
You're welcome BabaJ Glad to be of help.
@jsmack: That was also my initial thought.. so I looked it up the OPcustomize file, but there does not seem to be an entry that creates a new alias for the group sop.
Closest and meaningful one I found was on line (163) as mentioned above:
Unless.. is there another area where the aliases get configured by default?
EDIT: I'm on Houdini 16.0.550 Indie
opdeprecate -r "groupcreate" 16.0 Sop group
Edited by galagast - March 20, 2017 11:28:46
- jlait
- 6245 posts
The “group” alias is a shelf tool added to the tab-menu, so doesn't exist as a node. The override is in $HFS/houdini/toolbar/ExtraTools.shelf.
<tool name=“geo_group” label=“Group” icon=“SOP_group”>
<helpURL>operator:Sop/group</helpURL>
<toolMenuContext name=“network”>
<contextNetType>SOP</contextNetType>
</toolMenuContext>
<toolMenuContext name=“viewer”>
</toolMenuContext>
<toolSubmenu>Group</toolSubmenu>
<script scriptType=“python”><![CDATA[import toolutils
import soptoolutils
soptoolutils.genericTool(kwargs, ‘groupcreate’)]]></script>
</tool>
- galagast
- 252 posts
- baudy2
galagast
opadd group
Hello, I am sorry, but as been a newbie i do not understand where to type this ? Can you, please, explain more in details ?
I am following a couple of training videos and there is a serious difference in the Group SOP interface for H15 and H17 i use.
Thank you in advance for help.
