Hi
I have a digital asset I made at Obj level, is there any way to “move” it to the Sop context?
I tried to switch the toggle to sop, like in the screenshot and matching the current definition, but that didnt work…
Any help?
Changing HDA context without re-creating it from scratch
3261 7 2- SteN
- 55 posts
- SteN
- 55 posts
- alperenozgur
- 16 posts
- OdFotan
- 192 posts
- 8583 posts
OdFotantools Tab was just moved to Interactive/Shelf Tools
Is this feature removed? I don’t see this ‘Tools' tap in the the Type Properties..
Any chance of doing this in Houdini 18?
and while you can create a tool that appears in different context, it will not make your HDA a different context because the contexts are not compatible, that's why they are “different”
- OdFotan
- 192 posts
Thanks I see, what’s still confusing to me tho is this:
Does the context that the asset is created in also matter besides the context the asset contains?
For example I created a subnet in SOP level, which I now want to have on obj level as a geo node.. both types contain the context ‘Geometry’/SOP, but I do not get when I change the context, (did also delete and readd like @SteN said)
Edited by OdFotan - May 21, 2020 05:20:52
- 8583 posts
- OdFotan
- 192 posts
