SIDEFXLABS - VHDA Workflows
   6924   10   2
Hi Everyone,
Take a look at a new great workflow UX enhancements we have made for working with HDAs in Labs.
Let us know what you think. Please file RFE/Bugs with SideFX support. This thread is mostly for discussions.
Paul
Paul Ambrosiussen
Technical Artist, Freelance
twitter.com/ambrosiussen_p
Hey Paul, this is a great addition to labs!
Do you plan on supporting the Embedded HDAs? I use them a lot.
Nice addition!
Pretty much every studio I've been at rolled their own because the default way of making namespaced versioned digital assets is so prone to making errors.
https://www.linkedin.com/in/peter-claes-10a4854/ [www.linkedin.com]
Thanks for this, but how to turn this on?
I've updated LABs to version 603 (latest this window shows me), but I still don't have this option for versioning with gui.
Screenshot 2020-10-29 122808.jpg (45.8 KB)
That version of Labs (603) should have VHDA support. Do you see any other Labs tools? Or none at all.
Paul Ambrosiussen
Seems like everything working correctly, I'm using some of the tools, never experienced issues.
Do you have any other plugins / toolsets that might also modify the right-click OP menu installed?
I just tried 603 myself on a fresh install without anything else and it works for me.
Could you try renaming/deleting your preferences folder and try on a clean environment? (make a backup)
Paul Ambrosiussen
Just checked on 18.5, it's working there, no longer issue for me, thank you, Paul.
Screenshot 2020-11-05 104244.jpg (24.4 KB)
Is possible to make custom presets for the structure? We are currently saving our hdas inside a parent folder with the same name and with a new file for every version.
Example:
$MY_HDA_PATH/the_great_tool/the_great_tool_0.001.hda
$MY_HDA_PATH/the_great_tool/the_great_tool_0.002.hda
and so on
Aleksej Skrypnik
Example:
and so on
Hey! Yes, we will be shipping an update soon that includes a nice preferences menu for various things. (including that)
For now what you can do is set VHDA_PATH in your env vars and it will use that as the default preset values.
Paul
Paul Ambrosiussen
Ambrosiussen
Aleksej Skrypnik
Example:
and so on
Paul
I would like to set a global vhda.config file but I only can redirect the Preferences via the "HOUDINI_USER_PREF_DIR" environment variable. Is there a environment variable to directly set the vhda.config file? VHDA_PATH is not working for me.
Thanks for the nice tool.
Cheers Martin
Edited by louisx - Aug. 24, 2022 07:33:11
