Fuzzy flames problem
2884 7 1- hochenauer
- 8 posts
Hi, i´m working on a pyro sim, where a person starts burning.
I based it more or less on the spreading fire shelf tool.
It behaves quite well as expected, but i get a kind of fuzzy look, which i can´t pinpoint where it comes from.
The scene should be in scale and all the voxel parameters are set to 0.0045, should i go lower?
When i try to get lower the sim get´s stuck.
My machine is quite ok, it should handle this, i guess.
I attached a simplified version of the scene, thanks your for any tips.
best wishes
best wishes
- hochenauer
- 8 posts
- ati
- 186 posts
The fuzziness has nothing to do with the resolution. I can even lower the resolution. The reason is your disturbance force, you basically applying a very strong disturbance all across the fluid container.
I adjusted your setup a bit to get nicer looking fire. Let me know if you need further explanation.
Also try to use ACES, which will give you a much nicer looking fire on default.
- ati
- 186 posts
- hochenauer
- 8 posts
Thank you so much for putting the time into answering:
i was ramping different parameters, but i hit a dead end.
This looks so much better and also explains, why simply more resolution won´t give a better result.
As for using Aces with pyro/houdini:
I´m also a color grader, so i know Aces, but could you point me to the right direction how to implement it.
thank you, you just saved my weekend
Edited by hochenauer - Dec. 4, 2020 16:30:41
- 7794 posts
hochenauer
Download the latest configs from your github repo of choice, or build it your self from source.
https://github.com/colour-science/OpenColorIO-Configs/releases/tag/v1.2 [github.com]
Then export the path to the config as $OCIO in your environment. (how depends on your OS, but if only needed in Houdini, then it can be set in the houdini.env)
- ati
- 186 posts
Exactly as jsmack said.
There is also a doc written for this as well:
https://www.sidefx.com/docs/houdini/pyro/shading.html [www.sidefx.com]
- hochenauer
- 8 posts
