Setting ImageMagick env variable on a Mac
10126 22 3- kevinthebright
- 208 posts
- ubcsdelta
- 7 posts
If someone still struggling:
1. Install imagemagick via brew
2. Add this line to your houdini.env
The .env path is ~/Library/Preferences/houdini/18.5/houdini.env
3. Relaunch Houdini
4. Set ImageMagick binary option to $PDG_IMAGEMAGICK in your imagemagick node
Hope that helps
PS MacOS Catalina, Houdini 18.5
brew install imagemagick
PDG_IMAGEMAGICK="/usr/local/bin/magick"
3. Relaunch Houdini
Hope that helps
- OdFotan
- 192 posts
ubcsdelta
Thanks, that helped,
but for me (Also on Mac) the path turned out to be:
PDG_IMAGEMAGICK = "/opt/homebrew/Cellar/imagemagick/7.1.0-6/bin/magick"
Found the path by using the "Find Any File" App, {Name} {is} {magick}, and choose the one that seemed best (not the Alias).
Be aware there is the "ImageMagick Binary" parameter-menu on the TOP node.
This worked, as opposed to the directing to a self-made $PDG_IMAGEMAGICK_DIR and the "Use System Path", which did not work.
As such: PDG_IMAGEMAGICK_DIR = "/Users/username/Documents/Codecs/ImageMagick-7.0.10/bin"
Maybe this helps someone.
Edited by OdFotan - Sept. 7, 2021 05:52:10
