How to procedurally rename the CHOP channels?
   1432   4   0
I'm running a bunch of transforms on points and want to then output them to several objects but need to rename them to prefix them with the appropriate object object:channelin order for the export to work.
I don't see how I can rename the channels in a data driven way either already inside chops or on import.
Anyone tackled this?
Thanks.
have you tried Rename CHOP?
rename from: *
rename to: object:*
or Channel Wrangle CHOP
chrename() [www.sidefx.com] VEX function
tamte
rename from: *
rename to: object:*
Rename CHOP does not help because it's not a single object to rename to but multiple objects names.
I did not see chrename() when I checked VEX functions, that might be the approach I was looking for initially. Maybe it works in a newer version (I'm in 18.5.351) since I just tested it by prefixing with "box:" before the transform channel name and did not work but... there's a __name__ attribute there when MMB the wrangle... I'll test it further, thanks for the pointer!
I ended up using the Geometry CHOP parameter, "Point Name Attribute" which uses a string attribute to prefix the channel names instead of suffixing them with enumeration (tx0, tx1, etc..)
Edited by probiner - Sept. 8, 2021 23:31:53
probiner
to make it work change your Iterate parameter to Over Channels for example (help page contains more info)
tamte
probiner
Right, thanks! This is indeed the procedural way I was looking for, bit more work but may be worth it!
int digits = floor(log10(opdigits(CN))) + 1 ;
chrename(CN, point("op:../../ToCHOPS3", "chop_prefix", C/9) + CN[:-digits]) ;
Reorder was also needed to facilitate the access to the correct point.
Edited by probiner - Sept. 9, 2021 07:10:51
