ocean wave
2732 10 2- moritz-h86
- Enivob
- 2537 posts
- lewis_T
- 238 posts
- lewis_T
- 238 posts
- eikonoklastes
- 331 posts
- lewis_T
- 238 posts
- eikonoklastes
- 331 posts
- lewis_T
- 238 posts
- moritz-h86
eikonoklastes
Also easily doable without any VEX needed
tinyhawkus
Ooh you may be doing like above, just using the mountain or a noise.
You can make a wrangle that takes the relative bounding box of the axis your water is traveling down,
and use that in a ramp, then you have freedom to adjust the falloff.
Thank you for replying, can you please share the script? it's not working for me, I followed your instruction and didn't work, there is properly something wrong with my model.
- eikonoklastes
- 331 posts
moritz-h86Sure thing. Here's a scene, attached below.
And if you need to quickly see what was changed in a node, you can always click the Search and Filter button, and choose Parameters with Non-Default Values:
Edited by eikonoklastes - Jan. 24, 2022 01:27:13
- ajz3d
- 467 posts
