When I render with Karma every frame spams about Redshift Render
But I do not even use Redshift in this scene.
Redshift for Houdini plugin version 3.0.63 (Jan 18 2022 18:20:57)
Plugin compile time HDK version: 19.0.498
Houdini host version: 19.0.498
Plugin dso/dll and config path: C:/ProgramData/Redshift/Plugins/Houdini/19.0.498/dso
Core data path: C:\ProgramData\Redshift
Local data path: C:\ProgramData\Redshift
Procedurals path: C:\ProgramData\Redshift\Procedurals
Preferences file path: C:\ProgramData\Redshift\preferences.xml
License path: C:\ProgramData\Redshift
When I render with Karma output is spamming about Redshift
3346 7 3- AndreasOberg
- 117 posts
- rangi
- 306 posts
I'm seeing the same thing. I've been ignoring it, though I'm wondering if it affects load times - must do at least a little. Removing the env-vars that load RS seem to be the only obvious solution. For me I'm rendering with both so just living with it.
“First things first – but not necessarily in that order”
– The Doctor
– The Doctor
- mestela
- 1743 posts
- AndreasOberg
- 117 posts
- futuredeluxe
- IsStuff
- 237 posts
- jumax
- 74 posts
- cdordelly
- 123 posts
Hello!
Could you try to post this on the Redshift Forum? I Don't think that the RS dev will check the reports here.
https://redshift.maxon.net/category/38/bugs-solaris-hydra [redshift.maxon.net]
I'm wondering if this problem can be related to this thread also:
https://redshift.maxon.net/topic/46764/lag-opening-a-file-maybe-related-to-rs/8 [redshift.maxon.net]
You might try to rename the cpu dll too.
Cheers!
Cheers!
