Hey folks.
I noticed in the current production build that generating a flipbook is incredibly slow compared to earlier versions. I did a simple animation that plays just fine in real time on the timeline. When I invoked the flipbook it was taking more than a second per frame.
One object. Smooth wired shaded. Default head lamp. Low poly.
Anyone else having this issue?
H19 Flipbook Slow Performance
2990 8 4- Tobias Steiner
- 101 posts
- Gagui
- 45 posts
- dyts
- 105 posts
- 7803 posts
- mestela
- 1745 posts
- Tronotrond
- 47 posts
I can confirm I have the same issue and mestela is right. I have two license servers added in the License Administrator.
One local, and one only accessible when my work VPN is active. Removing the work server from the list made the flipbook generation go back to normal speed.
Guess Houdini is trying to check if it can reach all license servers for each frame it's "rendering"..
Edited by Tronotrond - Feb. 5, 2022 15:26:30
- mattw
- 175 posts
Hi, do you know what version of Houdini and hserver you are using? If you're using H19 the new licensing system might alleviate some of the issues. I think what's happening is that each frame has to go back to sesinetd to request a new license and under login licensing that can be a larger request time (has to contact servers in Toronto) than an on-site license server.
Matt Warner
Software Developer - Licensing
- Island
- 340 posts
- Tronotrond
- 47 posts
mattwIn my case it's License Administrator 19.0.498. It was the same issue with .455.
My localhost server is listed first. When I ran into the issue, the local server have all the licenses I needed, but I guess mplay perhaps still pings all the license servers for each frame - and it would wait for a timeout from the second listed server since the VPN was disabled. Just a guess here..
