It's the lame question time:
I have a curve, and I recall, I could reverse the direction using the Reverse SOP node. Now I cannot do that, apparently. Does anybody have idea?
How to reverse a curve?
5479 5 1- szmatefy
- 141 posts
- animatrix_
- 4528 posts
Perhaps you want to use Sort SOP -> Point Sort (Reverse)?
- Zybrand
- 91 posts
- 8594 posts
- szmatefy
- 141 posts
- Xeumz
tamtethanks this one helped me! wanted to reverse path of popcurveforce tried using sort reverse only but didn't work, adding what you said did the trick thank you
To properly reverse the curve you should use Reverse SOP
And then you can use Sort SOP in By Vertex Order mode to have points reflect it if you care about point numbers
