Hi. Woudl anyone know how to export materialX subnets out as a Material X shader?
Best
Mark
Exporting out as MaterialX
3864 9 3- Mark Wallman
- 647 posts
- 7770 posts
- rafal
- 1448 posts
There is a `vop2mtlx.py` script that exports a VOP HDA as a Material X shader. This is how we generate ramp .mtlx from the HDAs.
There is also `saveShaderNetwork()` function in there, that can save .mtlx from VOP nodes rather than HDA. But it can only handle one-level of subnet, since currently MaterialX does not officially support nested compound node graphs. Compound node graph is one that does not specify shader node definition (nodedef).
- Siavash Tehrani
- 710 posts
- rafal
- 1448 posts
Not necessarily. You should be able to right-click on any VOP node > Save > MaterialX...
This menu item essentially calls
vop2mtlx.saveShaderNetwork()
, which traverses the input chains. If one of the node in an input chain is a subnet, that subnet will be saved as a node graph. But if that subnet has another subnet inside, it will result in an error, because MaterialX node graph can't have another node graph inside.
- Mark Wallman
- 647 posts
Hi all. I just came across this which may help...
https://www.youtube.com/watch?v=RpShFmwjMzg [www.youtube.com]
Best. Mark
Best. Mark
- StefanA
- 51 posts
rafal
This menu item essentially callsvop2mtlx.saveShaderNetwork()
I'm testing this right now and I can't for the world in me read the mtlx file back in again. When I test with the built in shader examples it's works (testing standard_surface_chrome.mtlx as example).
But if I create a standard surface and then export that it will not work.
If I copy paste the code from the mtlx file but change the name from "SR_Chrome" to "My_Test"., and also the same for nodename..it will not work.
So is there anything else we can do to make it work?
Testing this on 19.0.561 (linux)
regards
stefan
- rafal
- 1448 posts
- azab4d
rafal
The terminal node in your VOP network may need to be the "Mtlx Surface Material" VOP. Ie, you need to feed your standard surface to it as an input. Otherwise USD file plugin won't detect which shader to start loading from.
Hello Rafal,
Without Mtlx surface material node it will not write anything to the xml file. but with mtlx surface material node to export from houdini will not write the shader under <nodeGraph> so it will read just the shader when importing it back without any other nodes connected to that shader like mtlxImage or any other nodes. I know clarisse can read the .mtlx file even if it hasn't <nodeGraph>. but houdini can't!
So, what should i do to export correctly a materialX shader from Houdini and read it back in houdini without losing the nodes connected to the main shader?
- 7770 posts
