H19 Viewport Refresh Bug
3911 13 1- Robot_and_Robot
- 30 posts
Hi!
I started experiencing a bug in the viewport with the last two or three production builds of H19.
Currently working on 19.0.657
Graphics card: RTX 2080 Super
PC: AMD Ryzen
A few examples:
1. Let's say I enabled the display points switch. After working for a while and then disabling the switch will still keep the points "blue". Help->Reset Viewport doesn't help.
2. Working with sops: sometimes the colour attribute will stick and won't go away even if deleted and not present in the Geo Spreadsheet. And not just that. The geometry in the viewport can appear to be completely wrong and not displaying the current state.
The ONLY way to refresh the Viewport is by creating a new scene tab. By the end of my working session I may have up to 5 new scene tabs all beacause of this bug.
Is there something I am missing? Any setting I should play around with?
Any help is greatly appreciated.
Thank you!
PC: AMD Ryzen
A few examples:
Thank you!
Edited by Robot_and_Robot - June 24, 2022 21:12:07
- Enivob
- 2538 posts
- Robot_and_Robot
- 30 posts
Enivob
That's just the current state of Houdini, that's why they've added Help/Reset Viewport option to the product. Instead of creating new ones manually, try that reset menu item.
Thank you! But as I mentioned above, Help->Reset Viewport doesn't help...
Edited by Robot_and_Robot - June 25, 2022 16:21:02
- Enivob
- 2538 posts
- Robot_and_Robot
- 30 posts
EnivobThank you! Currently running the latest Studio driver. Will install the Game one and report here for posterity.
So if you're using nVidia, you have two driver options, game or studio. Try installing the other option for your current video driver. There were some bugs related to specific driver versions.
- yuqingfx
- 3 posts
Robot_and_RobotExperiencing the same problem, here is a tricky way to avoid open too many tabs, when you working under sop content, create a sop node (any of them, like a cube node) and display it. when you re-display your original node, you may find the viewport works fine.
- N-G
- 209 posts
- Enivob
- 2538 posts
- N-G
- 209 posts
- 7794 posts
N-G
Seems they have removed it from H 19.0.657!
It was never part of Houdini. They would never put a feature in mainline that capitulates to a bug like that. The menu is from the Labs plugin.
There's no need for the menu. A scene view can be made fresh by closing the viewer, and then undoing the closure from the pane's menu.
- N-G
- 209 posts
jsmackThank you @jsmack It is under the Labs menu I can see it now.N-G
- Robot_and_Robot
- 30 posts
N-GjsmackThank you @jsmack It is under the Labs menu I can see it now.N-G
Still there in mine
- papahh
Really this its the solution? Im an Old houdini user and im really get annoying with this bug, I cant do anything without press the reset viewport under help manu, WHY???
its not only that the viewport its not refreshing. If I go up one level or whatever other Sop i enter or Dop, or Cop, or go back to geo, the view not update, and I can not see anything until I press the reset viewport buttom.
Will be a REAL Solution?
regards
P.
regards
P.
- juejuezi
- 27 posts
papahhMaybe in labs
regards
P.
