Cache LOP in 19.5
2748 16 0- Tim Crowson
- 240 posts
- 8585 posts
- mestela
- 1743 posts
- 8585 posts
Motion Blur LOP seems to be just a wrapper around Cache LOP with the same settings for rolling frame window (subframe sampling)
It seems to be adding Resample Transforms option which sounds a little bit odd as it seems like resampling already quantized motion samples into more samples
Why is that necessary, shouldn't every renderer be able to do such interpolation adhoc?
since it doesn't sound like it's evaluating the stage at those finer steps, just interpolating already limited samples from Cache LOP or am I misunderstanding?
EDIT: also as a quick observation the math to compute central difference velocity seems to be wrong, submitted a bug, but in meantime its better to avoid central difference mode
EDIT2:
EDIT2:
sidefx changelog
19.5.348
Fixed bug computing central difference velocities in the Motion Blur LOP. This node now uses a SOP Modify and the Trail SOP, which is both faster and should match other cases where the Trail SOP is used to compute velocity
Edited by tamte - Aug. 20, 2022 12:59:25
- 7801 posts
tamte
Renderers don't get the chance to. Hydra evaluates interpolated time samples and sends those to the renderer. I'm guessing this way, the renderer can be sent good samples with proper interpolation instead of relying on hydra which is known to be wrong.
- 8585 posts
jsmack
how does renderer then further interpolates those samples? are you saying it doesn't?
wouldn't that make all motion blur sampling setting on renderer redundant if it can't interpolate timesamples it got from hydra itself?
- 7801 posts
tamtejsmack
it can interpolate the samples from hydra, but the samples from hydra are themselves already interpolated without any way to control it.
- Tim Crowson
- 240 posts
- 7801 posts
- Tim Crowson
- 240 posts
- 8585 posts
It mostly feels like we have subpart workarounds for things that worked great in Mantra
MB interpolation is just one thing out of too many
But I still can't understand why interpolating in LOPs between cached samples and baking those interpolated samples is necessary, there is seemingly no new info gained from it
- 7801 posts
tamte
so you can feed the renderer 'good' samples to interpolate. Hydra only does linear interpolation.
- 8585 posts
jsmack
so
- Cache LOP creates discrete timesamples (A)
- the Resample Transform node linearly interpolates those (A) timesamples and produces more inbetweens (B), it doesn't evaluate stage at more granular steps so (B) are theoretically just unnecessary data
it also does just linear interpolation between closest timesamples (no cubic or subd)
however it does slerp transforms, which is correct for matrices
- so it sounds like you are saying that Hydra is in a way between renderer getting timesampes directly and does additional interpolation (maybe based on renderers mb settings?) to provide to the renderer
so by saying Hydra doing just linear interpolation you mean it does per component matrix interpolation instead of slerp? (both are linear, but the first one obviously wrong)
if that's the case then it sounds like Hydra interpolatin even (B) will not be exactly correct if they dont align
having to have them aligned sounds super painful especially for already precached usds
so it sounds indeed like a workaround until Hydra gets fixed or bypassed by renderers for interpolation of timesamples
Edited by tamte - Aug. 17, 2022 15:48:55
- 7801 posts
tamte
yes. It's the same as writing ifds. When you write an ifd, the transforms in your scene are compute at the time sample of the ifd--so it aligns with the shutter. In the case of ifds though, there is only one layer--the renderer gets the samples directly. Creating the timesamples in the usd to align with the shutter is a way to bypass hydra's interpolation.
- 8585 posts
to me it looks like the transform samples are interpolated from already limited cache samples
So if I want overall 2 time samples to not waste memory on deformation samples
But I want 30 xform samples, if the transform samples are interpolated from those 2 cached samples it's gonna miss all the unique movement in-between if the motion is defined procedurally in lops etc
It doesn't sound like IFD in that regard
I feel like there should be inherently different timesamples steps for caching and also writing out xforms compared to other values
Just resampling xforms doesn't make that much sense to me, it really sounds like only working around broken Hydra interpolation, but it's not gonna capture fast moving objects at specified steps
- mtucker
- 4441 posts
If you are authoring your transforms in LOPs, the best solution is to use the subsampling controls on the Transform and Edit Properties LOPs. Then you really do get the full-fidelity subframe time samples without having to cache every prim in the scene, and you only get the subframe sampling on the objects that need it.
The Resample Transforms LOP is indeed designed to get around the poor job hydra (and even USD itself) does when interpolating transformation matrices. This LOP uses a much better method for calculating the interpolation. As you point out though, it is still just interpolation. But at least you can get reasonable looking blur on helicopter blades and other quickly spinning objects when all you have is a USD file with inadequately time sampled transforms already baked in.
- 8585 posts
