Attribute as "depth" value on the SubDivide node?
1996 7 3- Adriano
- 408 posts
- antc
- 275 posts
- 7809 posts
Adriano
It seems i'm not able to use a point or primitive attribute as Depth value on the subdivide node, why is that? What is the work around please? Cheers, A.
You can't really subdivide different parts of a mesh by different amounts. Using groups is only possible because the subdivision creates a seam between the subdivided area and the original mesh. This seam can be stitched, but the topology isn't that pretty.
- 8597 posts
- animatrix_
- 4530 posts
I would recommend adaptive subdivision rather than trying to store final subdivision levels as an attribute, as that won't have enough resolution to have fine subdivisions. I used this approach on ocean interactions many times:
This caused a lot of problems for me also when I was working on the face cracks setup on X-Men: Dark Phoenix. Houdini CC works but the cooking times increase exponentially.
Needless to say there is an RFE if anyone wants to bump it up: #105822
In any case I did create 2 solutions, one using OpenSubdiv as is but merged points robustly without using proximity. The other solution involves rewriting Catmull-Clark subdivision from scratch using VEX (about 500 lines of code, nothing crazy) based on OpenSubdiv rules:
My version does a lot more than the default OpenSubdiv implementation though, particularly fixes several bugs and edges cases such as handling mixed geometry, where OpenSubdiv either messes up point positions or outright deletes geometry it doesn't like.
If anyone is interested, I do cover both approaches from scratch to final implementation in my VEX course
tamte
doing it in feedback for loop is a way to go
however I'd use Houdini Catmull-Clark mode even though it's much slower it doesn't create cracks
OpenSubdiv for some reason splits the mesh at specified Group, which is very unfortunate
- Adriano
- 408 posts
tamte
Thanks, cracks are fine i can always fuse them afterward. But i don't have more time to build the set up in a fullproof fashion now so I got that affordable HDA on gumroad that pretty much does just that. Sadly the method is indeed a bit slow but it does the trick.
A.
- Adriano
- 408 posts
animatrix_
I would recommend adaptive subdivision rather than trying to store final subdivision levels as an attribute, as that won't have enough resolution to have fine subdivisions. I used this approach on ocean interactions many times:tamte
Thanks Mate, no disrespect to your talent and experience, i just can't afford your patreon just for this purpose, found an other HDA for 10$ that does the trick so i kinda moved on already. But great stuff you created there for sure, i watched the video over it yesterday when searching, Nice stuff.
A.
- justin_bisceglio
- 48 posts
