Hi.
I've trying to work with matte objects in my current scene.
When i set it up with in "render geometry settings" it works fine with cpu rendering but not with xpu.
Is there a workaround or am i doing something wrong?
Karma Holdout Mode
4947 9 1- suesssebastian
- 11 posts
- dlee
- 431 posts
- suesssebastian
- 11 posts
- bender83
- 15 posts
- bender83
- 15 posts
- dlee
- 431 posts
bender83
Is this supported in 19.5?
Yes.
For full list of supported features in XPU please refer to https://www.sidefx.com/docs/houdini/solaris/karma_xpu.html [www.sidefx.com]
- AhmedHindy
- 129 posts
dleeyou just gave me the bright idea of trying XPU in production. This might actually be worth it now since we always have mattes.bender83
Yes.
- Vladimir Shelest
- 7836 posts
Vladimir Shelest
What am I doing wrong? (H19.5.337)
I've setup a render with matte object to get a proper holdout for my smoke. Everything looks good and in general render time around 9-10sec per frame in viewport with Karma XPU. But when I press "Render to Disk" render time become 1-1,5 min per frame... Why?
does it take 1.5 minutes to write out your scene, and then load it in again? You might want to use 'render all frames in one batch' if you have very fast frames.
- Vladimir Shelest
jsmackVladimir Shelest
I've tried to use 'Render All Frames With a a Single Process' but no difference. Same behaviour. Vieport render is fast, render to disk is pretty slow. I think this is depend somehow of matte objects because only one difference between renders is "render geometry settings" node with activated matte settings for some objects.
