I have a set of floorplanes, I have a target area. I want to run a loop over the input floor planes and once they exceed the floor area I have a stop condition. If I look inside the loop I have the correct result but outside the loop the last prim is missing. Attached is an annotated hip file trying to explain the issue.
I think its a simple issue regarding how I am setting the stop condition or loop but I cannot figure it out
Problem using a For-Loop Stop Condition to test Areas
1023 2 0- polimpiado
- 42 posts
- 8581 posts
as mentioned in docs [www.sidefx.com]
which means that loop will look at the stop condition value at the start of the iteration, and if the value is 1 it will not even process the iteration
the fact that you process the same nodes that compose the whole iteration to compute the condition value is irrelevant
to delay the stopping to next iteration, simply feed back the geo to next iteration and check your detail attribute value from fed back geo
since this will happen at the beginning of the iteration, loop will stop as soon as the value passed from previous iteration is 1
meaning that the iteration that produced stop value of 1 will still be processed and output, but the next one will immediately stop
attached fixed file, which also contains alternative solution using loop in detail wrangle instead of foreach sop loop
This condition is evaluated before the loop is processed.
Edited by tamte - April 21, 2023 04:02:42
- polimpiado
- 42 posts
