How can I have the parameters panel on the top left in this scenario?
My 2 screens setup is the following: left screen for the scene viewport and right screen for the network pane maximized.
Problem is that, as the screenshot shows, the parameter panel is fixed on the top right (of the right screen), forcing me to constantly rotate my head left and right whenever I change some parameter.
Ideally I'd be able to have the parameter panel on the top left of the right screen, which means it would be close to scene view of in the left screen.
Any idea how to do that?
As far as I researched it seems impossible..
thanks for help,
Andrea
Hot to set Parameter panel on the top left when network maximized
5320 6 1- Andr1
- 118 posts
- BabaJ
- 2048 posts
You could hold down the middle mouse button in a blank spot of your nework window and drag all the nodes closer to the parameter panel.
You also can click on the most upper right white down pointing arrow which gives you the option to split network window to “split pane left/right”
Then just make one of the windows a parameter window by right clicking on the upper tab of that window which then gives you the option to change it to a parameter window ( amongst other types ).
- Andr1
- 118 posts
- goldfarb
- 3456 posts
- alnh
- 17 posts
- martinkindl83
- 260 posts
- animatrix_
- 4548 posts
I never needed to position the parameters pane overlay but I reckon it can be done with Python Qt scripting.
Similar to how I created the overlay network editor, you could create overlay parameters pane to be stuck to a network editor.
You can get some ideas here:
