Vex Edit String Window: Search and Replace Highlighted Only? -> NO!
   663   7   0
Hi!
I've got about 40 lines of code and I need to replace "string" by "float" for the last 20 lines only. In the editor (Alt + E in a wrangle) I have the option to "Replace All" but I don't get how to replace in the hightlighted text only. Is it possible?
...at worst, I'll just replace all and copy paste the text I need....
-Olivier
Edited by olivierth - Nov. 21, 2023 14:35:14
There is no find and replace in highlighted function. Just do it the old way and hit replace a bunch of times until it's changed all the ones you want to change.
Alright, thanks for the info!
-Olivier
You can make Alt + E hotkeys to open an external code editor where it is more convenient and easier to do it and save the changes to be applied in the snippet window.
alexwheezy
That part never works for me.
jsmack
alexwheezy
Hmm, maybe it doesn't work with any IDEs. When I tried saving code through sublime or neovim it worked.
I just copy and paste in Sublime Text for such things since it has search and replace for selected text.
Edited by BabaJ - Nov. 21, 2023 15:59:57
BabaJ
I just make a compiler directive to change the meaning of one thing to the other.
