Hi!
Sometimes when I use a for-each primitive sop, it doesn't update the changes I'm making prior to the for-each. I've tried using the bottom right “manual” function and clicked on refresh but nothing happens.
Any help?
Thanks.
-Olivier
for each sop NOT refreshing (have to restart houdini)
1524 4 2- olivierth
- 1007 posts
- FJSam
- 18 posts
- Un1ess
- evanrudefx
- 225 posts
- 8555 posts
I don't recall having that issue, however whenever you are displaying a node between begin and end block (and not forcing the cook of End node in any way) then what you will see is a cached result of a single iteration flowing out of Begin node
so changing upstream will not have any effect, and you can either cook the end node, or click on Reset Cached Pass on Begin or End node to refresh
