according to docs SOP Import LOP is automatically converting pscale, width and widths attributes to widths
but it doesn't seem to convert the values
while nowadays pscale in houdini represents radius
widths in USD represents diameter (according to USD docs)
so I'd assume it should also convert between radius and diameter (and vice versa when importing back to SOPs) because currently SOP viewport shows one size and Karma renders another
pscale vs widths conversion (radius vs diameter)
5097 6 4-
- 9434 posts
- 8191 posts
- 9434 posts
jsmackright, but regardless, the USD specs defines it as diameter so I feel like it should be consistent on Houdini side
I've seen inconsistency between how the widths value is used in the viewer depending on which delegate is active.
the fact that both pscale (radius) and width (diameter) in SOPs map to widths without value conversion shows already this inconsistency regardless of whether widths would be radius or diameter, one of them would always be converted wrong
Edited by tamte - Jan. 30, 2020 14:09:30
CG Supervisor
Framestore, NY
CG Supervisor
Framestore, NY
- cwhite
- 802 posts
- 9434 posts
- TheNotepadShow
- 92 posts
- robp_sidefx
- 605 posts
