H9 file import lists a .eps file as readable , yet I cannot get a .eps file from illustrator cs to work ?.
Rob
.eps files
12844 17 3- circusmonkey
- 2624 posts
- edward
- 7760 posts
- probbins
- 1145 posts
you could possibly convert the eps to a bgeo file with the command line utility,
geps, which comes with houdini.
eps files are problematic since there are an endless number of flavours.
“gravity is not a force, it is a boundary layer”
“everything is coincident”
“Love; the state of suspended anticipation.”
- edward
- 7760 posts
- circusmonkey
- 2624 posts
Thanks so much for the answer. I had a bash at it, created a .bat file to run in the cmd line but I cannot get it to run correctly.
#Usage: geps infile.eps outfile.*geo
So I input
C:\Program Files\Side Effects Software\Houdini 9.0.748\bin geps.exe
C:\Documents and Settings\circusmonkey\Desktop logo_CMYK.eps
C:\Documents and Settings\circusmonkey\Desktop CMYK.*geo
but I get this error
C:\Program Files\Side Effects Software\Houdini 9.0.748\bin>C:\Program Files\Side
Effects Software\Houdini 9.0.748\bin CMYK.*geo
'C:\Program' is not recognized as an internal or external command,
operable program or batch file.
I know its my fault as to why its not running ..any pointers ?
Rob
So I input
Rob
Gone fishing
- symek
- 1390 posts
- circusmonkey
- 2624 posts
- circusmonkey
- 2624 posts
well you would of thought this would be simple , but no.
.bat file = failed
Houdini command line
G:\Projects_vfx_houdini\GFI_LOGO\geo> geps glogo.eps logo.bgeo
Token %%Note: not found.
Unable to convert EPS file glogo.eps
can anyone or should I say has anybody ever got this to work. Id love to know what token is being looked for and where I am suppossed to put it lol
Rob
.bat file = failed
Rob
Gone fishing
- digitallysane
- 1192 posts
- edward
- 7760 posts
- digitallysane
- 1192 posts
edwardI tried right now to import a very simple (one rectangle) Illustrator file, in AI3 format, exported both as ai (extension changed to eps) and real eps, and got erros on both versions, in Houdini as well as in geps.edward
The real problem is that the “.eps” files that geps understands are actually .ai files.
Dragos
- old_school
- 2540 posts
- Fr3drik
- 36 posts
Here is a script for Illustrator that exports Houdini readable eps files. Not written by me.
http://www.preset.de/2007/0705/illustrator/ [preset.de]
Works great btw!
Works great btw!
- Fr3drik
- 36 posts
- circusmonkey
- 2624 posts
I saw that script . The only snag is I do not have illustrator2. In the end I gave up with .eps. I could of just fired up Maya but that would of been a cop out. In the end I went.
Trace SOP to read in the logo as a image and a combination of Curve SOP > Resample SOP > Carve SOP. Although it was a fiddle at least I got the job done
Rob
Rob
Edited by - Oct. 16, 2007 22:13:38
Gone fishing
- edward
- 7760 posts
- Fr3drik
- 36 posts
- AndrewVK
- 136 posts
