Just started with HD a couple of days ago and everything was going great but now I have some issues. One I posted earlier on the public beta section about camera giving an error in the console (cam1 evalInt: Invalid parameter name trange)
Now, ignoring the message (it appears at random) I decided to revisit one of the video tutorials on modeling. A chrome material is applied to the spoon. The first time I watched the video everything worked fine on my end as I followed. But today, when I applied the chrome material, it looked like black plastic. So do other metallic materials.
Frustrated, I uninstalled HD (9.5.134) and reinstalled it again (9.5.140) and the materials are still the same!
Am I doing something wrong? Is it possible to damage the material definition?
Thanks in advance
Strange Behavior - Maybe because I am new?
12052 15 1- cwkoch
- 5 posts
- cwkoch
- 5 posts
- circusmonkey
- 2624 posts
- cwkoch
- 5 posts
Well, it makes sense. However, as I mentioned before, when I first followed the video tutorial (from the sidefx video tutorials) one wasn't needed. The preview would show the chrome material just fine. In the tutorial, the spoon is modeled and applied the material without an environment map and it worked just fine as I followed it.
Something happened along the way and the material got corrupted or something. If you look at the tutorial, there's no extra step after applying the chrome material. 2 days later, I went to follow the tutorial again because something I was trying to do reminded me of the tutorial and that's when I noticed that the metallic materials had changed.
Again, I don't know if there is a way for me to damage the material library. But even after reinstalling the software twice it still doesn't show the materials the same way as they were…
- josh3light
- 120 posts
The latest versions of 9.5, have been giving me some problems as well. For example, most of the vops were missing and I'm getting error messages on startup. All of the materials from the palette, when added to shops, errored out as well. I am currently installing and reinstalling to see if I can fix the problem as well.
Update:
I found that it was a problem with my Houdini OTL path environment variable. I took that out and it's working fine now.
Update:
- TAVO
- 19 posts
don't know if you solved the problem but i have the same issue with 9.1.244 version, even when following the first video tutorial about the interface, i just cannot make the letters split when they fall down with the dynamics applied, i re-watched the video 5 times and follow step by step and i just can't make it, so i just want to know if something was changed or it is a bug or it is me or something, thanks for any comment on that.
I'm using Houdini Apprentice 9.1.244 version on Fedora 7 32bits if that helps. Thanks.
- goldfarb
- 3455 posts
- TAVO
- 19 posts
- goldfarb
- 3455 posts
- TAVO
- 19 posts
got it, but i don't fully understand it, it only works if i'm inside the AutoDopNetwork but not if i'm on obj mode, i mean in scene mode, but maybe it could be because i'm not totally aware of Houdini yet, have to look at it more carefully, the thing is if you follow step by step the video tutorial you can't get the same result anymore ?? or i made that mistake ??
Anyway, thank you for you time, i have to play a little bit more
- goldfarb
- 3455 posts
- TAVO
- 19 posts
thanks actor, i will look at the file and see where is the mistake, if there is one or is just a bug.
EDIT: well, yes, i just found that you have to click in RBDFracturedObject or RBDGlueObject to make it work, but if you click in just the RBDObject as the video does it…………it doesn't work :?
About the chrome material, i've been playing with reflection maps and you can get the same result as the video, apparently older versions assigned a defaul enviroment material but not in recent ones (9.1.244), not sure. I will have to read “changes from previous versions” more often
- rmagee
- 1182 posts
TAVO
Actually in the video, I hover over RBDObject then realize that it is the wrong tool and quickly click down on RMBFracturedObject. We should have editted out the hovering part because the actual click is on the fracture…
TAVO
The best solution is for us to get an environment map onto the chrome material. There are several available but we just haven't updated the material. Thanks for the reminder.
- goldfarb
- 3455 posts
- cwkoch
- 5 posts
TAVO
Well, I was using 9.5.134 when I first got the same result as the video tutorial, then it broke. Also, I have never been able to see “changes from previous versions” as I *always* get and error “Incorrect Version!”
rmagee
So, I'm not crazy, thanks! Now I have to learn how to apply the environment map.
Did I mention that the more I learn Houdini, the more I *LOVE* it??? Makes any other 3D app seem like a toy
- chrism
- 2496 posts
cwkoch
That was one of the first bugs I logged when I got here. There's been a few changes in the software since those videos were made.
Chris McSpurren
